1 - 4 of 4 Posts
I drove a four hour drive to the desert and the next day I saw a trail of water my thermostat will go up a little higher than usual then drop. There was also coolant splashed by the radiator I replaced the cap and it’s still leaking water from the middle of the car behind the engine bay
Breast inspector by appt.
simple like this, water draining from the a/c, the pipe drain hole is exactly where you said the leak is.
1 - 4 of 4 Posts
