***List of Wheel Sizes, Offsets, and Tire Sizes for RSX.
1356345 Views 1558 Replies 604 Participants Last post by  mfarmakas17
2
PLEASE DO NOT PM ME ASKING WHAT WILL FIT. I ONLY KNOW THE INFO ON WHAT IS POSTED BELOW.
RSX Wheel Offsets and Tire Sizes.
All sizes and offsets listed below are known to work and have been used by a member here. Another tire size or offset may work than those listed, if you have used or are using an offset and tire size that is not listed below, post a reply to the thread and I will try to add it. Please be sure you know the offset works before posting and pictures always help too.
Shown below is a list of wheel sizes, offsets, and tire sizes known to work with them. All of the information below is based on RSXs without widebody kits and unrolled fenders. This way everyone will have an idea of what works on a stock body, lowered RSX. Also, these sizes are without the use of wheel spacers.
I hope this helps everyone...
Updated 04/07/07
-Stock Offset and Sizes-
'02-'04: 16x6.5" with +45mm offset.
'05-'06: 17x7" with +45mm offset.
-Bolt Pattern and Lug Nut Size-
These also apply to aftermarket wheels:
Bolt pattern: 5X114.3 (means 5 lugs spaced 114.3mm apart)
Lug nut size: 12mm X 1.5" (12mm thread size by 1.5 inches long)
-OEM or Stock Body and Fenders ]-(no alterations to the body of the car to make them fit)
16X7: +40. Tire sizes: 205/55-16 to 225-50-16.
16X7.5: +43. Tire Sizes: 225/50-16.
16X8:
16X8.5:
16X9:
17X7: +35 to +60 Tire sizes: 205/45-17 to 225-45-17. (ideal offset is +42 or +43)
17X7.5: +40 to +48 (+35 w/ no drop). Tire sizes: 205/45-17 to 225/45-17. (ideal offset is +42 or +43)
17X8: +35 to +48. Tire sizes: 215/45-17 to 245/45-17. (245/40-17 was used with +40)
17X8.5: +30 offset with 215/45-17 Tire. +40 with a 235/45-17 Tire.
17X9:
18X7: +37 to +45. Tire Sizes: 205/40-18 to 225/40-18. (ideal offset is +42 or +43)
18X7.5: +38 to +48. Tire sizes: 205/40-18 to 225/40-18. (ideal offset is +42 or +43)
18X8: +37 to +48. Tire Sizes: 225/40-18.
18X8.5: +45. Tire sizes: 235/40-18.
18X9: +40. Tire size: 245/40-18 ALSO>> 18x9 +29 offset, 215/45/18 tire
19X7: +40 to +45. Tire sizes: 215/35-19 to 225/35-19.
19X7.5: +43 to +48. Tire Sizes: 215/35-19 to 225/35-19.
19X8: +35 to +47. Tire sizes: 215/35-19 to 235/35-19.
19X8.5:
19X9:
20X7:
20X7.5: +42. Tire Sizes: 225/30-20. NOT LOWERED! Only on '05 and up???
20X8:
20X8.5: +42. Tire Sizes: 225/30-20. NOT LOWERED! Only on '05 and up???
20X9:
-Offsets, Hub-Centric Rings, and Counterbores-
Basically offset is the distance from the centre of the wheel to the part of the wheel that sits against the hub of the car (mounting pad), more commonly measured in millimetres (mm).
As you can see in the diagram above, a positive offset is when the mounting pad of the wheel is toward the outer edges of the car and a negative offset is when the mounting pad is towards the centre of the car more. An offset of zero is the absolute centre of the wheel and would have an equal distance to each side of the mounting pad. For the RSX all of the offsets should be positive (+) I don't see where you would want or need to use a negative offset at all. The offset will change on wheel width too, you won't have the same offset on a 9" and a 7" wide wheel and have them fit the same on the same car.
When you buy aftermarket wheels the centre bore of the new wheel will be much larger than that of the stock wheel, this is because of the wide range of hub sizes on different cars and not all cars are made the same. So what the wheel manufacturer will do is make the hub size the largest so it will fit over any hub and then a hub-centric ring must be used to make up the difference between the RSX's stock hub size and the aftermarket rim center bore size. These are usually made of plastic or aluminium and should come with your new wheels to prevent any vibration that may occur. Without them, your wheel will not be truly centred on the hub and at certain speeds, your steering wheel may shutter and/or vibrate, just like an unbalanced tire - not a good feeling.
Reactions: 5
41 - 60 of 1559 Posts
Does anyone know what the stock 02 rsx-s wheels 5 lug wheel pattern is? I want to paint my stock wheels black but i need other temperary wheels on it so i can still get to work. I don't care what kind, brand,steelies,manufacuturer..etc., i just want them to fit the pattern.
thanks
I run 18x8 with a 48mm offset and it fits fine, no rubbing. 225-40-18 tire.
so I have a question, 17”x7.5 with the offset +38 in the front and +42 in the rear will fit my car? I have just eibach pro kit, according to the list 17x7.5 goes with +40 to +48 or +35 w/no drop, I don’t think my drop is that big, will they fit,
Thanks
Great thread. My only question is, can someone tell me what are the specs on an '02 Type S stock rim? I just bought a cert-preownd SSM '02 and was looking to change the rims but keep the tires (since I don't have that much cash to lay out right now and plus the car came with nice 205/45 Continental tires). I have my eyes on the TSW Kyalami (hyper black with silver lip) but since I'm a newb, I have NO idea what size I should be getting. I know I want to keep the stock tires (since they're practically brand new) and I know that there are 5 lugs on RSX wheels so I've come up with that much. So it's obviously 17" and 5 lugs, but as for width and the distance between the lug holes, I'm totally lost. Could anyone help a newb out and point him in the right direction? Thanks!
The bolt pattern should be 5x114.3, since the 05 type s wheels fit fine on older year models. Width I don't know but the 05 wheel is 17x7
Anyone have a pic of a lowered rsx with 18x8.5 sized wheels? I see that the chart says a 18x8.5 wheel will work but not sure about ride height.
Thanks a lot andrew! :thumbsup: I was also debating btwn these enkeis too. Any opinions? The TSWs or the Enkeis? Also, does it matter if the bolt size is even a little off? Like if the bolt pattern is 114 versus 114.3? Should I only be looking for bolt patterns that are exact matches with the car? And what is the difference btwn a 205 tire and a 225 tire on a 17"x7" wheel? Anyone have either of these rims with a SSM Type S? Thanks for all the help and advice everyone!
wow very nice... thanks
Now a days most cars have a 5x114.3 bolt pattern, yes you have to have the right bolt pattern or the wheel with not fit. Both 205/225 tires should fit on a 7" wide wheel but the 205 might be stretched and the 225 might have a little bulge. I have little experience in what size tire fits what size wheel. You should check out tirerack.com, they have some tech pages that have lots of useful wheel/tire info.
great thread... but do you think you can indicate on the list what stock settings are?
One last question, anyone know what the offset is on an '02 Type S stock rim? Thanks!
omg ....THANK YOU SO MUCH FOR ALL THESE INFOS!!! THEY'RE REALLY HELPFULL!!
Here's what I have on my car:
SSR Comp 16x7.5 +43 with 225/50/16
wow.... i now know everything i will ever need to know about tires lol. great thread props for blackbird for taking time to compile all this info
Does anyone know a 18X9 offset/will it work?
what offset though...
I think a +40 may work...:dontknow:
Damn. . the ones i'm looking at are 18X9 with a 38mm offset
Could work if you are willing to roll fender, cut fender lip, or run some serious negative camber...:thumbsup:
I would imagine years may vary slightly making tire clearance a moving target. On an 06, Acura, RSX type S, I have installed 17 x 8's, 40mm pos offset, with Kumho 245-40-17's. Car has been run and cornered hard and have yet to rub. If I were to do it again, I would go with a 48mm pos offset to push the wheel in another 5/16".
Bronco Rider
