1 - 1 of 1 Posts
Just some FYI for your list...
Tenzin said:
Here is lists of mod that i am thinking about doing soon:
HKS CIRCLE EARTH SYSTEM: $125.95
---> Make your own out of 4ga audio grade wiring and connectors. About $40 for everything and works just as good. Just find out the proper mounting points.
TEIN S. TECH SPRING KIT: $173.00
---> I suggest some good dampers along w/ this.
Spoon Sports Racing Spark Plugs - $112.00
---> Totally not needed, nor will they give any significant gains.
KingMotorsports Big Bore Throttle Body by 4mm more - $ 150
---> I believe it's 2mm overbore...King's site is incorrect (and they're too lazy to change it)
GoodRidge Steel Brake Line - around $173.00 - done
---> Before you get SS lines, get a good set of pads and better tires first. Remember, SS lines are only for FEEL...so you can better modulate the brakes. No good if the brakes themselves and tires suck.
1 - 1 of 1 Posts
