1 - 5 of 5 Posts
· Registered
I Removed The Cruise Control & Fog Light Switch Since I Dont Use Them And Added A Voltage Meter/Dual USB Charging Port, Kept The Sunroof Switch & The Switch To The Right Is For My Fans, I Have My Fans Wired Off A On & Off Switch So I Can Manually Control Em. Im Using A Dual Electronic Fan Harness Made By Us @PremiumRaceElectronics
· WILDCARD!
2006 RSX Type-S
Looks pretty clean. Good work!
Just curious, why do you like manual control over the fans?
Oh, and is it annoying having your charging ports on your left? Seems like you'd have to have the cord draped across you or put your device down in the door pocket?
Reactions: HeelFlips
· Registered
You Can Use The Charging Ports But i Have It So I Can See If It Drops Voltage Or If Its Over Charging. I Just Use The Stock Charging Port On The Back Of The Steering Column. When I Use The Ports I Usually Have My Phone On My Lap Or I Have Something Extra Charging As Like Earphones, iWatch, Etc..
· Registered
Look pretty cool, but I can't help but show off my switches lol. Sorry for the gross stains, need to clean up my interior this weekend. I am pretty much going for a more stock looking / hide yo switches look.
  • Left of the steering wheel is a subwoofer knob so I can adjust the amount of bass from my JL 10" sub.
  • 3 switches under the headunit storage for fog lights, shift number indicator, and red LED underglow under the seats.
  • Drilled out the small red LED that was suppose to be some cup holder light? Installed a descret black toggle switch for my exhaust valve. Catback is a stock Type-S, but where the catalytic used to be is one of these exhaust cut out
1 - 5 of 5 Posts
