1 - 20 of 30 Posts
Anything fast and brutal
Ok guy's, I was lashing the valves on the Z3 head today and happened to notice that the upper cam chain guide looked different to the one on the bench from the A2 head. The one on the engine is for the K20Z3(06'-07'Si) head and it bolts onto the A2 and A3 head as well.
So next time the VC comes off add this for a added piece of mind for your high RPM ventures. part# 14540-RAA-A01
The A2/A3 upper chain guide is in my hand, notice the shorter length of the plastic guide!
tq is nice
damn! good find doug! might have to do this....cheap safety like you said...
You could just change this when you change your valve cover at the same time right?
Infinite Motorsports
what does this help with?
Helps Keep the chain on and lined up on the right tooth when you trying to put the damn tensioner back on.
1 - 20 of 30 Posts
