1 - 8 of 8 Posts
CIVICes1
hey guys , like tittle says, loosing coolant (green fluid)
today after driving couple of miles, I decided to open the radiator cap and see the level of coolant on my radiator, so I grabbed a towel , placed over the cap and opened slowly . after it released the pressure I removed the cap and normally its all the way to the top, the coolant. but today I could not see any of the green coolant , so I decided to add a complete 20fl oz water bottle just to see how low it was, I didn't have any coolant , I know I did wrong but its better than nothing right? and it took the whole bottle and coolant was exactly to the neck, water turned green , and had small amounts of foam, possibly the coolant boiling , nothing major, guess that's normal? I daily drive my ep3 45 miles , its a 04 with 98k miles . bought it with 90k miles and never added coolant to the reservoir tank, because my radiator was always full, so I decided to not even mess with the radiator if its not giving me any heating problems. and to this day temperature guage marks normal . so u guys think coolant was just low due to the hot days here in LA lately? or should I have it checked?
I haven't noticed any leaks. well I will add some coolant to the reservoir tank this weekend and keep an eye on it. what brand do u guys recommend? also do u guys think the radiator will be ok with those 20 fl oz of water I added till dec wen I get the coolant drained ? SORRY IF IM ASKING A DUMB QUESTION BUT I ALWAYS GET SOME POSITIVE GOOD REPLYES ON HERE! thanx
Seems like your coolant is going somewhere. I change mines every 2 years and my coolant has never disappeared, had always stayed at where I left it off at. I would check in case though. To me it just doesn't sound right. But I could be wrong since you live in a much warmer climate then I do. I just changed my fluid 2 weeks ago and I poured in almost the whole jug that it comes in with. I used premixed 50/50 btw. If there's no leaks I'm assuming there's nothing to worry about.
ride height Nazi
you check you catch tank.....inside the passenger wheel well....it its cracked, you will loose it in the heat cycles.
CIVICes1
mustclime , if by catch tank u mean the plastic tank that has a small hose to the radiator neck, yeah ive checked it and its empty, and it does have a crack at the top of the tank, missing piece , size of a dime. can I use a seal or some type of tape? could this be the reason my coolant went low?
cja3455 , no white smoke.
ride height Nazi
replace it...thats your coolent leak most likely...while your at it, replace you radiator cap with a new honda part...
1 - 8 of 8 Posts
