1 - 8 of 8 Posts
How do i turn off the maintenance required light.
on my old integra, there's a button under the steering column that you hold down and it turns off.
how do i turn it off on my rsx?
thanks
UnDr PrShR
For the bazilianth time here it goes......
get in car put key in ignition ..but do not turn ... use left hand .. push reset button for the speedo /tripometer (sticking out of the instrument cluster ) & hold it down ..now turn the key to the on /run position ..but don't start the car . hold till flashing maint light goes out then release turn off key ... then start vehicle as u normally would & light should go out . this light is for oil & filter / regular intervals service ..as per mileage.
my light flashes like 5 times when i turn on my car? it is cause by the oil change? i changed it about 4000 miles ago but i didn't change the filter because it was stuck, so im guessing its that
Premium Member
it gets to where it flashes a few times after a certain amount of mileage, then works it's way to staying on.
yup
no it just flashes at a certain number of miles and then it stays on after another preset number of miles
Premium Member
it starts from the time you reset it. but if you reset it at the proper times then yes.
1 - 8 of 8 Posts
