1 - 5 of 5 Posts
SocalRSX
Which harness is better for a Kenwood DDX712?
MET-70-1725
or
MET-70-1721
All I'm going to be hooking up to it is the factory Bose speakers, Amp, Bass Box, and my ipod.
Are you amplifying your speakers or just your sub?
If I understood correctly from a little research you won't be able to use the 1725 harness if you're amping your speakers. If not go with the 1725. From what I read the 1725 gives better sound quality.
The Audio Guru
1721 is used if you are bypassing the bose, or have a Base. 1725 is the integration harness that let you use the Aftermarket HU's RCA's to integrate it with the stock RSX Type S bose system.
1 - 5 of 5 Posts
