1 - 2 of 2 Posts
I have a misfire on cylinder 1 on my 2006 type s, I’ve bought new spark plugs , my ignition coils are only 2 years old and I’ve switched around my fuel injectors. It’s a headache tryin to figure out what’s going on, could anyone point me to the right direction ?
I would switch the ignition coils--needs to be eliminated as a possiblity no matter how old. If it stays on 1, you need a compression test to see if it's a compression issue. If it's then determined to be a valve, you can check clearance. Easiest things first.
1 - 2 of 2 Posts
