1 - 4 of 4 Posts
if anyone can help me with my issue I would appreciate it!!!! my cars starter wire was loose so I took off my throttle body and put it on correctly I had recently got new parts from a part out which was a injen sri and a new denso map sensor so I figured to install them as well my air temp sensor was short and I decided to cut it and extend the wires and I also put that part out map sensor on my car and as soon as I put everything back to together I noticed my car sounded like a Subaru 馃槶馃槀 and it was misfiring and idle weird I don鈥檛 know what I could have done wrong I checked the connections that I cut and they were good I even tried putting back in my old map sensor still no fix I also even cleaned iacv and still no fix any idea on what I should do now ? I have even changed my throttle body gasket and when I try to scan the car it tells me I have a misfire in cylinder 1 3 and 4 the motor cannot be bad it was very healthy before doing all this
06 RSX Type S VBP 06 RSX Type S Milano Red
Check your spark plugs and if they look good then it is probably your coil packs that need replaced.
1 - 4 of 4 Posts
