1 - 20 of 87 Posts
New update Post 78 The install has begun!!!!
Turbo install complete, phase 1!
:wavey:I have been a long time lurker here as my best buddy aftershock141 is on the boards with a boosted dc5. I decided to register and slowly post in some of your threads, and he said I should post up my car. So here it is.:giggity:
1991 Toyota mr2 NA to turbo swap. Bought with 66,000 miles, now with 98,000 miles. Under 12,000 miles on the rebuilt block.
Mod list so far..
Suspension/Brakes
Sportmax 962 wheels
17x7 +40 front
17x9 +35 rear
Hankook pII 405 tires
205/40/17 front
255/40/17 rear
Tein S-tech springs
KYB AGX struts
Prothane bushings
High and tight sway bar end links
Drilled and cross slotted rotors
Porterfield RS4 pads
Earls SS lines
Inside
93 shift lever
98 shift knob
Red/black stitched Leather boot
JVC Arsenal series cd player
Kicker CompVT
Eclipse EA4000 and XA1000 amp
Polk momo 6.5" fronts
Polk db 4" rear
DEI alarm/keyless
Omori boost gauge
Prosport EGT and oil pressure (replacing soon)
Double pillar pod
Engine
twos r us manual boost controller
HKS ssqv
Cold air intake
OEM shifter cables
ARP headbolts
Oil catch can w/ breather using Earls fittings
Blitz Nur Spec exhaust (replacing soon)
Eagle rods 3SGTE
JE pistons, rings
Clevite main, rod, thrust set
Toyota high-flow oil pump
Aftermarket water pump
Timing belt (goodyear Gatorback)
Toyota genuine Tensioner, Idler 1 and 2
Cometic HG
Toyota genuine overhaul gasket set
Misc
Kaixen HID 6000k lights
Soon to be installed/Sitting in room
ATS td06 with 38mm Tial external gate, dumped
SS coolant and oil lines
KO racing 3" downpipe
Custom 3" magnaflow dual exhaust
KO racing intercooler piping
ATS rom tune ecu
Front/Rear strut bars
Coming
hondata s300 conversion (custom setup)
Ksport coilovers
TE37's, CE28N, or Jline wheels:confused:
gt3082
Speed source top feed rail
880cc injectors
dual intake walbros with -10AN out
GSC 268 cams
ATS custom intake manifold
4" intake
etc..
Now my car history from day 1!!
Stock non turbo 5sfe engine, 66k miles.
I decided to buy another crashed mr2. Buying a rear clip is easier than just buying the turbo motor. You get everything from the seats back that you need. Body harness, motor, brakes yadda yadda. With this FULL car I also got seats, wheels, spacers, and lots more!
The shop where we did the swap. Black crashed painted and red mr2 are mine. Everything else int he shop is my friends.
Discussion Starter #4
Here is the engine after pulled it from the black mr2. 177,000 miles into a 66,000 chassis :(. Hey I got it for a good price, so no biggy! So gross and oily, definatley needed more work than I intended, oh well here we go......
NA motor pulled from my red mr2, preparing for the turbo guts!
Discussion Starter #5
Well 6 months later in about Novemeber, this thing was dripping oil left and right. I had enough and decided it was time for a rebuild. Why do it like a sissy! I had a local mr2 master built me a fully forged block, with all the goodies!
Block being broken down
Port matching
Discussion Starter #7
Parts for when it gets warm out
Engine as it sits currently in storage
More coming..:shady::noes:
Discussion Starter #8
Well thats the build for now. Here are some outside pics and such.
Amps in the frunk!
1 more set to go...:noes::noes:
Discussion Starter #9
That is it. Post any questions about anything. I like to chat:run:
Prepare for an update March, after the turbo install etc..etc.. with dyno numbers!
MEGATRON!
Man I love MR2s :drool: great car man. Looks fucking sexy from behind. How much hp/torque you puttin down down?
Aftershocks got an awesome boosted car too, for a base :laughing:
Discussion Starter #12
Never dynoed the car yet, still on my stock turbo. I will update in March when I install the new turbo. Currently only like 230whp tops. Once I install my tuned ecu and turbo I should easily be around 340whp fuel limiting. My goal is for next summer over 500 with gt3082. Once I do my hondata conversion as well.
b0000000000st
Absolutely freaking ballin. My friend had an MR2 that he had big plans for, but he totalled it a few months ago :(. I see you're shootin for 350rwhp! I don't know much about Toyotas or turbos, so do you think you'll make it?
Good luck with the build, man. You should get plenty of support from here.
beastly. that gets like 170HP stock right?
Discussion Starter #16
Stock turbo no, its already choking at 17psi above 5000rpm. The turbo in my last post the shiny one is a Mitsubishi td06 20g. Lots of dsm's run them. Highest hp on this turbo on a mr2 is around 470whp. Ill be able to make it no problem. What is holding me back now currently is 550cc injectors and tune. I am converting my car to run off of hondata. Then I can upgrade to top feed 880's and get a real tune, that should last me all of summer until next winter where my goal is paint/body and 500whp.
Maybe rate aroudn 200hp or so? Not to sure, I have maybe 220-230 at the wheels now.
Member
omg thats awesome, i love mr2s, wish i knew how to do that much technical stuff on a car...
Omnomin' outta control
God damn nice car, that generation mr2 is one of my all time fav's :drool:
Did he post a vid of the two of you racing by chance? If so I am the one who asked for pics :laughing:
Again, great car dude.
1 - 20 of 87 Posts
