1 - 20 of 127 Posts
RealTalk
Hey ClubEP3 haven't had the pleasure to start a member show off thread due to being next door in the CRSX turbo section. I want to take the time to move over here and try and keep updated the progress of the EP3 project i have had going for the past 3 years since i first joined the turbo side. It all started with a revHard kit on my k24a1 that gladly made 350hp/315tq and lasted a good time and had a blast with it for the time being, it all change when i did a vtec killer setup on the same motor but with a couple changes ranging from top mount manifold to new turbo and engine tuck. That setup got me a lovely 410hp @ 10lbs of boost but sadly due too many variables the motor died on the dyno. It all fastly changed to my recent setup i now have and have had since last Feb thanks to the tuning and patience of Brian @ speedlab.net who sponsored me in my tuning needs. I finalized the setup in my garage with hand tools and no help what so ever, i also assembled my own engine together and all the misc. toys it takes to put together a turbo setup. Onto the pics and description of my recent build..
BEFORE
AFTER/RECENT
2012 : 04 CIVIC SI TURBO BUILD
K20Z3 MOTOR [stock]
EP3 5speed transmission
CC stage 4 6 puck clutch
OEM flywheel
ARP headstuds
HONDATA 4bar map sensor
HONDATA KPRO
AEM water/meth kit
AEM mac boost solenoid
AEM wideband o2 sensor
RBC intake manifold
SS custom top mount manifold
CX racing 2.5" intercooler pipng kit
Evo9 fmic
PTE 6031jb turbocharger
Vband custom 3" downpipe
Vband custom 3" catback
VIBRANT 3" ultra-quiet turbo resonator
TSUDO 3" turbo muffler
TIAL 38mm wastegate
TIAL 50mm bov
ILR dumptube
K2ND half-size radiator
K2ND 12' slim fan/shroud
K2ND silicone hoses
K2ND heater delete plug
K2ND upper cooling housing w/filler neck
KARCEPTS RBC adapter
KARCEPTS iacv delete
KARCEPTS a/c delete n alternator relocate
INOVATIVE 95a billet motor mounts
GOLDEN EAGLE fuel rail
WALBRO 255 fuel pump
PTE 880cc injectors
BC racing BR type coilovers
Wedsports TC05's 17x8 +38
245/40/17 front
225/40/17 rear
FnF rear lca's
Progress rear tie&sway combo
Energy Suspension Master bushing kit
BREMBO big brake kit
s2000 slotted/drilled rotors
And a couple videos from my channel of the kills..
http://youtu.be/lZOd8Gd4mmk
http://youtu.be/IGo_NEs9pwE
http://youtu.be/hSrdHUHafls
http://youtu.be/7vykDxf-XX0
http://youtu.be/V8XyB_qJR5s
http://youtu.be/HTqIh2QRZSU
http://youtu.be/DrNkUozA_8Y
http://youtu.be/QFsLaWbB04k
BEFORE
AFTER/RECENT
I now have a totally new setup for TX2K13 this year that's under wraps and i was hoping to have it ready for the upcoming COTM{so come over to crsx and vote for me fellas}, but due to now officially owning a 2006 subaru sti i have slowed down a notch and hope i have the time to proceed and not give up.. But any who i hope u guys like my show off thread i put together and ill try and keep it updated on the upcoming events itll undergo, till then fellas stay tuned!! :bow:
Hellafunctionnal
Question regardless your brake setup
What knucle are you using, brembo caliper from dc5 ?
last one did you have to fab some bracket to hold the caliper
Great car love the intercooler and the wheel !!!
RealTalk
Discussion Starter #5
Im using the usdm knuckle off my ep3, the caliper is off an acura tl.
No bracket was fabbed plug n play.
Hellafunctionnal
wow great
tl type s brembo with s2k rotor and that's it ?
i'm currently running ep3 type r brake swap with hp+ pads but may need to upgrade the system any sooner or later but this probably might be my way to go
RealTalk
Discussion Starter #7
wow great
yes.
RealTalk
Discussion Starter #9
How does it handle when you set it into a corner? Any rubbing at all?
after installing the front polyurethane bushings on the lca's to be honest i can take a sharp right of left turn at a very decently high speed and no rub at all. BTW front fenders havent been touched and i still have fender covers
Hmm, I might have to consider going for 245s when I want race tires. I was going to go for 225s but if you can fit 245s I'll need the extra grip. I'm going for a very similar setup with a turbo k24a1
RealTalk
Discussion Starter #11
That'll be good. I had the 235's and 20-40mph rolls I'd roast them. These 245's had proven the diff., in the future I will be getting 255's
RealTalk
Discussion Starter #13
Yeah I am running 215s right now and on 6psi I just shred through them in the dry. It's pretty bad
i hear ya i was making 426hp on 14.5lbs and ill roast them 225's and 235's all through 3rd gear and part of 4th!!!
ThePagoda
I opened a separate window on my phone to keep up w updates !! Love this car. I guess since its close city and made in tx it has my upmost admiration.
RealTalk
Discussion Starter #19
1 - 20 of 127 Posts
