101 - 120 of 650 Posts
Spooning on you!
Discussion Starter #104
Yes it's the HR kswap intake.
The intake must be trimmed in order to fit unless you want to cut your fender lining then you don't have to. I chose to cut the intake. You do have to buy a smaller battery, stock battery hits the intake.
Yes, HR rsx rad hoses are used upper and lower. Can't use the stock rad hose on top, interferes with the intake.
Awesome build man, very track oriented! :thumbsup:
Did you feel a big difference in braking when you upgraded from OEM to Spoon Monoblocks? And is the rear wing really necessary for the track? I'm heading for track in less than 2 weeks from now, and I'm a bit nervous that my rear end will be a bit twitchy around tighter corners, with no aero, and the 16k/28k spring rates :ugh:
Ronald
Spooning on you!
Discussion Starter #107
Ronald
the brakes do come in handy. the wing is not necessary but i got it because i got a good deal on it and i think it looks cool as well. :ricer: ill be adding more go mods to the car in the future where the wing will be alot more effective.
when on a track, all you reallllly need are good tires and good brakes.
Spooning on you!
Discussion Starter #116
J's rear strut bar
1 off custom fab relocate clutch reservoir bracket by anointed aero and blackndecker. Thank you guys. The work is superb.
