1 - 5 of 5 Posts
· Registered
Which motor mount is more likely to go bad first?
When in low rpms (2000-2500) if I press the gas I'm hearing a very loud noticeable "thunk" from the driver side part of the engine. Which I'm assuming is the driver side mount, but I could be wrong and it could be the front mount. I've also heard that the driver side mount is the mount that goes bad first/more likely in rsx's
Feedback? Answers?
· i eat f00d
it always seems that the front mount is the first to go..
you can easier check the passenger mount - its right by the power steering pump - the mount is liquid filled.. if its busted you should easily see black stuff everywhere.
the front and rear mount - you have to get under the car to check. you may as well check both while you are under there.
the tranny mount is underneath the air box. but i have not normally heard of this mount failing.
· Registered
thanks!
I actually got the driver mount replaced and it drives great! no engine vibrations, well obviously becuz its stock mounts, but its exactly how I wanted it to feel.
· Banned
Feedback? Answers?
Hello all, what are the OEM part numbers for all 4 RSX mounts? I have an 05 RSX
1 - 5 of 5 Posts
