1 - 3 of 3 Posts
i install stage 2 clutch...with flywheel...in my car rsx-s 06.....when i put everything back together....my gears r not in the same place....for examle 5th is supposed to b all the way to the right n up....well now is like were 3 is supposed to b....they all go into gear .just not in the same place...
i have done 3 clutches b4 n this has never happend....well i guess is the first...
any support ....i will apreciate ....n thanks in advance....
are you saying that 3 and 5 are switched or that all the gears are just moved over closer to the driver's side?....you may have switched the two cables on top of the transmission by accident
no man there not switch.....is like 3 n 5th move closer to the driver side... specialy 5th..
1 - 3 of 3 Posts
