1 - 20 of 45 Posts
I've been reading that many people have been getting grinding problems in mostly 2nd gear. I get grinds too but, the only gear I would get it in is 3rd gear. I've tried many things to solve this, and I've finally found something that works for me and my car.
When I'm driving, if I rest my hand on the gear when its already engaged, it tends to grind the next time(s) I go back to my 3rd gear. However, when I don't rest my hand on any gears during the drive, I no longer have a grind problem. I've been doing this for about a month now, and I have no grind problems.
I drive a 2006 RSX-S that has 20,000-20,500miles.
tq is nice
hmm....i have a k20a2 swap with the 6spd....my second gear is touchy...i have to shift somewhat slow otherwise it wont go in....at WOT....but at normal driving i have no problems....
Retired OG
Manual states
not to rest your hand on the shifter when its in any gear....
(it could damage trans)
That may be the reason your having problems in the first place...
:rotfl: oh no
Premium Member
you aren't supposed to be resting your hand on the shifter anyway. the only time you touch the shifter is when you are actually changing gears.
LOL I've rested my hand on the shifter at times too... lol... not too much tho cause I like to have 2 hands on the wheel on the highway and most of my driving is done on the highway.
Uh oh i rest my hand on the Shifter...i am going to stop though no reading this thread
How does resting your hand on the shifter cause tran. problems
probably pushes the shifter ever so slightly one way (like if your in 6th resting it on there it'll push it toward 5th) which will wear out certain things... I dont know what tho cause I know jack schidt about trannys :D
Mmm, 3rd lobe...
You are putting a constant pressure on the collars. It would take a long time to actually break anything like this IMO, but its definitely not a good habit.
^ Exactly ...
You can actually feel the difference in the gear shift..
If u slightly touch the shifter you will notice minimal vibration
as you apply more ABNORMAL pressure.... you can see an increase in vibration which is OBV not good...
Pistol Grip and Resting hand on shifter FTL :shakehead: kids....
I rest my hand on automatic cars tho :p
1 - 20 of 45 Posts
