N/A K-Pro Calibration Thread
This a thread where we can all share our calibrations.
To submit a calibration:
1. Give it a unique name.
2. Write your engine code and modifications down.
3. Write down KManager software version used.
4. Link to the calibration, or upload it as an attachment.
5. Include datalogs if you would like.
Post this information, and I will edit this first post with your entry.
This way we don't have to search everywhere to try out someones calibration.
Keep this in mind.
For more information, check out Conrad's RSX page:
http://pencomputing.com/rsx/
Conrad is an upstanding member of this board with a vast knowledge of computers, electronics, and vehicle tuning. There is a great amount of info on the K-pro, basic tuning techniques, and advanced tuning on his site.
-------Calibrations-------
palmerblock
motor: K20A2
mods: Injen CAI, JRRH w/ high flow cat, exhaust
palmerblock's original calibration
palmerblock's modified version (corrected lean condition at high rpms)
Glimpse
motor: K20A2
mods: Injen CAI, JRRH, 2.5" exhaust, Toda N2 cams, PRC IM
KManager version: 1.1.2.0 (would not operate with 1.1.3.x)
This is the original N2 calibration supplied to me by Toda. It is untuned.
Original N2 Calibration
3rd Gear Pull Datalog #1
3rd Gear Pull Datalog #2
3rd Gear Pull Datalog #3
9bells
motor: K20A2
mods: AEM V2, DC RH, IMG, AEM PULLIES, **STOCK EXHAUST**
Notes:
- 94 octane ethanol blend.
- This is a fully tuned calibration.
94octanemohawkfinal.zip
motor: K20A2
mods: ITR CAMS & MANIFOLD, AEM V2, DC RH, 2.5" CUSTOM EXHAUST, IMG, PULLIES
Notes:
- 4200 VTEC, 8600 rev-limit
customitr94octane.zip
WhiZ
motor: K20A2
mods: AEM V2 intake and DIY grounding kit
- IAT was 101 degrees (my usual IAT) and I have not applied conrad's temp compensation to it
- Fuel used was Chevron Supreme 94 octane
- I logged an A/F range of between 13.0 and 13.8, but primarily it's very close to 13.2 from 3k RPM to 8k RPM
- VTEC point is at 4500RPM; rev limit 8600RPM; immobilizer, Multiplexor, and OBDII are all enabled
k20a2-rsx-coldair for WhiZ final tuned for 100 IAT.zip
motor: K20A2
K-Manager version: 1.1.6.0
Mods: V2, ITR cams, JRRH with hi-flo cat, Greddy SP2 exhaust, DIY ground wires
Notes:
- Started with ITR calibration and tuned from there
- January 27 2005 running on Chevron Supreme 94 octane (only in Canada, eh?)
- Immobilizer and all OBDII functions are enabled. VTEC is 3800rpm and fuel cut-off is 8800rpm.
- Additional notes click here.
k20a2-rsx-310cc-itrcams-jrhdr-cai whiz kinetic tuned final for dyno.zip
park83rsx
motor: K20A2
mods: Injen CAI, DC RH, DC TCS exhaust, ground wires, TB coolant bypass, Hondata IMG
KManager version: 1.1.3.0
Notes
- IATs were extremely low, in the 30-40 degree range.
- I applied conrads air temp. compensation to it, but the 0 point is about 30 degrees.
- First calibration is milder, I recommend running that first. The second one is more aggressive.
- Both calibrations improve the mid-range where the engine seems to want more timing due to the increased flow of the header and exhaust. (over just a cai, which is what the base (cold air) calibration was tuned with)
k20a2-rsx-coldair-dcrh-dctcs.kal
k20a2-rsx-coldair-dcrh-dctcs cam advanced ign tuned.kal
Datalogs...
Untuned CAI kal.....very lean...1-3 gear pull
First calibration, 2nd gear pull
Second calibration, 2nd gear pull
Second calibration, 1-3 gear pull
andyd22
motor: K20A2
mods: Mugen CAI, DC Sports Header, Skunk2 Cat Back
Notes:
-Needs to be converted for U.S. users.
-There are some knocks still @ low rpm, but these had been modifed from these 2 logs.
-As u can see 0-60 in 5.8 0-100 in 13.806.
-Still needs a little tuning.
K20A2 Palmers Run4
Datalog 1
Datalog 2
TheSilverBullet
motor: K20A2
mods: Injen CAI, DCRH, Comptech catback, ACT Prolite, ACT Stage II, ESMM, CSS
-street tuned
1k20a2-rsx-coldair_dcrh_1_10_2005.zip
tedmaneight
motor: K20A2
mods: Injen CAI only
KManager version: 1.1.5
Notes:
- fixed air fuel, checked for gains +/- 5 deg cam, and fixed knock at cruise
- dyno tuned
CAI Only dyno tune115.zip
PacDog
motor: K20A2
KManager version: 1.1.5.0
Notes:
- dyno tuned
- AF needs cleaned up slightly
011905pacifico.1.zip
NOTE: Any of the above calibrations you run at your own risk, especially if your modifications differ significantly from the original tuner's.
Keep this in mind.
palmerblock
motor: K20A2
Glimpse
motor: K20A2
9bells
motor: K20A2
Notes:
motor: K20A2
Notes:
WhiZ
motor: K20A2
motor: K20A2
Notes:
park83rsx
motor: K20A2
Notes
Datalogs...
andyd22
motor: K20A2
Notes:
K20A2 Palmers Run4
Datalog 1
Datalog 2
TheSilverBullet
motor: K20A2
-street tuned
tedmaneight
motor: K20A2
Notes:
- dyno tuned
PacDog
motor: K20A2
Notes:
- dyno tuned
