1 - 9 of 9 Posts
I always stood by skunk 2 products but idk what just happened today. The cap/head part of the drain plug broke off now the thread part inside the transmission but it doesn't leak. i need a mechanic or somebody With the right tools to help me out with this . I will drive to you. Just don't want to be dealing with the headache of it leaking transmission fluid in the future. Any help is greatly appreciated thanks in advance
Go to a welder and put it back together and tack it up
dang that sucks, I just bought a set and havent even gone through an oil change yet. Did you torque these? Just use some vise grips, make sure its tight like where you use all your strength to close the vise then turn them.
You could use a small cutting wheel like those used on a Dremel to slot what's left and turn it with a screwdriver.
Sidemarker Mechanic
I solved his problem :)
Sidemarker Mechanic
If you looked at it closely, theres still some "stud" of the screw outside of the transmission. I basically took a vise grip, and spun it out. It wasn't stripped inside, so it came right off.
Luckily this was aftermarket drain plug.. If this was OEM, if the head of the screw broke off.. You probably crack the transmission case or mess up the threads first before the screw breaks apart..
1 - 9 of 9 Posts
