1 - 2 of 2 Posts
So I get this 02 rex base with a turbo from my work it lost a wheel and they come to pick it up btw I work for a tow company so I call popalock to make my a key they made the key but could not match to ecu so after going through the car I found a bypass cool right so that's fine I think but cant get it to crank get 1 click so I put a booster pack right on the starter and it started to crank
So I put a new start in and put a little bigger starter wire from the fuse box to starter because I found a cut in the wire and bad connection to starter and after all that same thing 1 click with no booster and slow cranking with booster
Btw battery in hatch and was 12.6v and the key is working no key light and secury alarm is off
1 - 2 of 2 Posts
