1 - 4 of 4 Posts
im doing my drivers door actuator, and i got everything apart, including the silver rod that goes from the mechanism to the key slot, but I cant get the actual gold rod that goes from the handle to the mechanism off...how does it come off the bottom?
I got the top clip off but I cant get the pin to slide out??
its starting to get dark would like to get it done before that...
Thanks!
Shiny side up!
Is the gold rod the 1 that is threaded?? if so it will be covered by a plastic snap piece ...pop that off (will be snaped on both sides )then pry rod from threaded part (reasonable force ) taking note of amount of thread sticking up over the top of plastic that it is set into ....otherwise door will not open ..or not open well from exterior door handle.
i got it just took more force then i expected....problem now is that I took the one screw outta the mechanism to remove the actuator and the piece the cable goes into popped out(its suppose to) but now i dont know how that gold peice the cable is attached to goes back in haha. anyone?
1 - 4 of 4 Posts
