1 - 11 of 11 Posts
i installed them yesterday,and why the light is so high,even it is much higher than the high beam,then how can i fix it ,
do i need to buy a x-clip to fix it,
and if i need,where i can buy the x-clip.
thx in advanced,all the answers will be appreciated.
You need to re-aim your headlights after you install the HID. Use the aiming screws.
Also, make sure the bulbs are seated correctly in your housings.
You need x-clips to hold the bulb securely into the headlight. If the bulbs are secure, not moving around, then you don't need the extra clips.
If after you install the bulbs, they still move around, you'll need to add the clips.
Another reason maybe that the bulb is not seated properly in the opening of the housing. You can go with an x-clip or just a cut out of the xenondepot flashing that people were using. That is what i did. A little more ghetto than the x-clip but far less work.
yep...cuz i heard somewhere here before that when u move ur aim up or down both moves ....
1 - 11 of 11 Posts
