1 - 17 of 17 Posts
LOL wut
Hey i need help on my 60ft! i have no idea why im getting such bad times... i think its mainly my launch but any advice will do! thanks guys! :shakehead
LOL wut
haha i got 2.7 on the 60ft...yup at the Q...i had them stock tires with normal driving psi...i forgot about dropping pressure...what psi is favorable again?
San Diego OG RSX
i think its about low 20s. The problem is how are you going to fill the tires back up when you leave to go home. Driving at 22 PSI = :shakehead :nervous:
LOL wut
haha i got it on ebay...it is worth the money! i think the seller has a few more...the sellers name is wrxworld...and i got mine for a total of 587 includinh shipping...amazing huh? yeah i dumped the clutch...im gonna feather it next time
hondata'd
i lowered my stock michellins at the track as low as 17 psi. yea i know! thats pretty low....but i know people that put there psi to 14 psi (ericcarver1, if you know him on the boards) just practice your launches...or buy better tires. Azenis arent a bad choice and alot of people have good results with them.
i use 215/45/16 azenis ...work great
and i use nitto nt555r 205/45/16 which produce consistent low 60 ft times. 2.1's maybe lower if your a real good driver.
if your in so-cal...im selling my 2 nitto drag radials mounted on stock rsx rims
http://forums.clubrsx.com/showthread.php?p=2240122#post2240122
good luck on improving your 60 ft's
San Diego OG RSX
what were your 60' with michelins at 17 PSI? did they make a significant difference or was it just .0000005 seconds better?
hondata'd
my 60 fts with my michellins were high 2.2's....
ericcarver1's best 60ft's with stock michellins at 14 psi was a high 2.1
TeamDC5
sameee 60 ft. problem
i just got back from the track tonite for my first time. FIRST THING--My launches were hidious..i have 17's with 215/45/17 bfgoodrich kdw's deflated to about 25 psi, and cudnt hook. my sixty foot times were between 2.48 and 2.7 which is horrible :thumbsdow . How do most of u guys out there launch, for example like do u slip the clutch or feather and at wut RPM? i was slipping the clutch at about 3500 rpms.. thanks..
Yeah the Michelins aren't that hard to launch on. My problem with them is they want to spin at the top of 1st and on the 1-2 shifts.
I usually pull 2.18-2.20's, but I've pulled a few 2.14-2.16's on the stockies. It's not too hard. I just lower my pressure to 23lbs, launch about 4500-5000, and slip the clutch.
And those times are without the J's Torque Dampner on or ES MM's so don't think it's impossible to get decent 60fts out of the stockies :thumbsup:
I just sit back, relax, and slip it in and out. Just ride it for a few seconds then pop it. It's a rush and a good feeling at the same time. :thumbsup:
you should be banned
I don't think I need to explain why.
1 - 17 of 17 Posts
