1 - 2 of 2 Posts
ASSISTANT MASTER MECHANIC
Okay here is the deal..
I had my safc unit on the passanger side seat... I had some heavy books on top of it.. I didn't see it there when I put the boooks down.. anyway so I go to the post office turn the car off.. come back out turn the car back on and it didnt sound the same so I checked the safc and I was like oops shouldnt have had it uner there... but here is the thing.. when I went to check my high/low throttle setting instead of seeing the normal bar graph it was just a flat line and at the end of the line it says OMIT..... I tried to change the fuel settings but it won't let me.. I can navigate through the menues and i can check each rpm but it wont let me change anything...
has anyone had this same problem?
Discussion Starter · #2 ·
Close one...
Never mind...Lee & Rich @ Cybernation helped me out...
I guess the display got locked up...
Solution was to hold the joy stick in the up position for 2 seconds..
But I think it has to be done while in the HI/LO throttle menu..
Apexi stupid mistake #2 by Pep...
Thanks again CN
1 - 2 of 2 Posts
