1 - 3 of 3 Posts
Well it was snowing here in Central Maryland, and I was trying to get home after I installed my Strup raceheader and Hi power exhaust. My check engine and battery light came on. Threw codes for the o2 sensors and my Cam position sensor. The car's factory rev limiter does not work, like when you are at stop you can rev it and ay 5500 rpms, a 2 step will occur, but not anymore all it does is rev. and when I am driving, thats when my 2 step will occur, at 5500 rpm. I replaced the Battery and Alternator, but it is still doing this..someone, please help!!
Breast inspector by appt.
Under dash fuse #4 is blown. Check the O2 sensor wiring, it may be damaged, or you may have just shorted out the fuse with snow on the sensor wiring, but that would be weird, it's never happened to me.
1 - 3 of 3 Posts
