1 - 9 of 9 Posts
I have an 06 RSX base that needs struts I have coilovers on it right now but they're trash. I'm going to take a drive about an hour away in this kid is going to sell me for struts from 02 RSX he doesn't know if it's S Series or base I'm just curious to know if it will fit my strut Towers and everything else that goes along with it any help would be greatly appreciated
02-04 struts are different than 05-06 but if swap the whole thing, it wont be a problem
Discussion Starter #5
What do you mean swap the whole thing all I'm asking is will the bolts fit into the tower inside the engine bay and will it line up with the hub assembly
The coil springs on the fronts are wound differently between the 02-04 and 05-06 struts. The whole assembly will fit though. You just cant swap the dampers and mix the springs.
Discussion Starter #7
Well I bought them and plan on putting them in tomarrow will it be ok? Like will it effect how it drives
1 - 9 of 9 Posts
