1 - 5 of 5 Posts
please help me! i posted in another fourm (performance) that i was having a problem with my car. It is under topic(base rsx motor problem) and the solution was to reset the ecu. How do i go about resetting the ecu. please help. Thanks
Before you pull that negative cable, make sure you have the code to your Acura radio otherwise you'll be locked out. To avoid that altogether, just pull the fuse for the ECU under the hood in the fusebox above the battery.
1 - 5 of 5 Posts
