1 - 14 of 14 Posts
Went to start the car this morning, step on the petal and there's nothing. The petal was just flopping around. I assume I need a new clutch. . I'm sure aftermarket ones are comparible in price as what the dealership will want. Where you guys getting parts - clutches-from these days? Possible master cylinder issue?
Doesn't Give A F*ck
So you can push the clutch down and it comes back up? Any air noises?
Or does it stick to the floor? Check your fluids and touch around the pedal area for leaks inside and outside in the bay
I'll have to check when I'm back in Canada. In SoCal now. But the petal was going down with no pressure and not coming back up
Doesn't Give A F*ck
Sounds like a cmc. Just get the em2 cmc, pass on the acura OEM one. Has flaws.
Discussion Starter · #8 ·
Definatley low on fluid. The reservoir doesn't have enough in it to even come out the line any more. I'll probably change out both while I'm in there and the system is bleed any ways.
I might go with the Honda one without the triangle piece of Acura one - I need to look model number. Anyone try the Honda one?
Discussion Starter · #10 ·
I took a peek under the hood. Looks like it's coming from CMC. There's only two of the three bolts left on the triangle piece.
For any others looking for prices, the dealership's are 46920-S5A-G06 for $185, 46930-S7C-E02 for $75.
Doesn't Give A F*ck
Yep. That's what happened to mine
Heard a loud pop and looked.
Discussion Starter · #14 ·
Fixed. Hardest part was getting the stupid tube on the bleeder nipple of the CSC. the Civic CMC feels a lot better.
1 - 14 of 14 Posts
