1 - 8 of 8 Posts
I just picked up a pioneer head unit from Crutchfield and I've notice reduced reception in some areas. Does anyone know the cause of this? I used crimp connectors and didn't solder. Should i take it out and solder the wires? Also, I used a kit so I could keep the stock amp. Thanks
Pancakes
Typically aftermarket radios do not have as good of an FM tuner as a factory radio. Pioneer is usually better than most, make sure you got your antenna plugged into the head unit all the way.
Doesn't Give A F*ck
yeah, be sure its on there tight. i know its hard to push in, but use the muscles your mother gave you.
The first time it wasn't pushed in enough and reception sucked. Reception is just reduced in some areas and a non-local radio station which I used to listen to a lot no longer comes in. I expected better reception not worse. Does HD radio change the reception at all?
The Audio Guru
Nope HD won't make a difference. This is a common problem with aftermarket HU's and the RSX, the rear glass antenna is optimized for use with the factory radio's and sucks for aftermarket units.
1 - 8 of 8 Posts
