Look what I found...I would think it would be a direct bolt on to our catbacks. A great solution for swapped cars and a way to keep smog legal. What do you guys think? Anybody ever hear of this mfr.?
i think that is a very good deal... and like musty said... you will either need to run a type s midpipe or you will need to have a shop cut your stock one 3" shorter...
I'm buying that header. But I'm getting the version with out the cat and I'm just going to weld at $50 cat in. High flow cats don't last very long anyway, so i'm going to save some of the cash. Going to just buy a 05-06 RSX S mid pipe. Inside diameter is 2.1" which is enough for a bolt on EP. Glad this came along, its the same design as the JR RH but cheaper.
Unless you have solid motor mounts, your motor moves under load. Honda uses a flex joint at the joint between the shortie header and the cat on the ep3 and dc5. The dc5 has another flex joint right before the tail pipe. Any rh will require an upgrade in the motor mounts. Even so, many people have had the flex joints fail on the dc header. Since the BC header uses springs and slip joints for this flex, you just tend to get more and more blow by as the header gets older....any header that does not use some kind of flex joint will have a limited life span with any car without solid motor mounts.
so if i get this and want to the install, i'd also have to get the flex pipe as well as a type s mid pipe and cut off a lil off the tip? how big is the type s mid pipe? sorry for all these questions.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
