1 - 11 of 11 Posts
What’s up CRSX. I just switched out my stock shift knob from my 06 Type S and opted for USDM aluminum knob and shift boot adapter. Instructions seemed fairly simple but boot seems to sit kind of low. Can anyone verify if I did it right?
-Tony
After
568160
568161
Before
568159
So I followed a video of a guy installing same setup without instructions and he installed it differently than instructions but it does hide the shifter and nut. I switched mine but not sure I like the way the boot looks now :unsure:
568164
568165
Premium Member
you can do what I did with mine and put a zip tie under the collar that way it'll stay in place
Original Owner
2005 acura rsx type s
i just realize that i had that piece when i had my tan interior and didn't transfer it over when i swap interior. but it did hand low like your first picture.
Thanks for input guys. I’m still unsure which I like best. I’ll most likely leave as is and switch it up later if anything.
Past Driver’s Ed
I have the same setup. Just a heads up, that cool looking aluminum shift knob isn’t so cool to the touch after parked in the sun. I felt like the thief Harry in the Home Alone movie reaching for the red hot doorknob. That sucker gets pretty hot.
Discussion Starter · #9 ·
Lol. Yeah I already got to experience the burn as it’s quite hot in California this time of the year
Been Around for a while
Go with the TSX or similar, that is what I have been running for a while. A long time back I had the all alum in So Cal, it was quickly removed
Discussion Starter · #11 ·
I like the feel/weight behind the aluminum knob compared to the stock plastic knob.
1 - 11 of 11 Posts
