21 - 27 of 27 Posts
I’m currently having the same issue. No crank no start. Replaced harness and nothing still. Immobilizer key flashes faster than usual when you turn key. No fuel prime, computer says it’s off when ignition is on.
I'm completely stumped. After countless hours of checking voltages and wires I'll I've got is when the key is off I have 12.3 Volts to the ecu and when the key is on I have zero. Does anyone have any ideas
What wires did you check for?
Im
Having the same problem car is a 2006 type S I swapped fuse box I keep blowing fuel pump fuse and a 15amp fuse next to fuel pump relay by the glovebox
What were you doing when the issue occurred?
21 - 27 of 27 Posts
