1 - 4 of 4 Posts
ive got a problem building boost. new boost controller found a couple leaks in the piping so i pulled it all apart and hooked it up to my compressor and pressurized it. fixed the leaks. any ideas what could be the problem.
M.I.A.M.I.
make sure all couplings are connected properly with t-bolts. Check for any vacuum leaks.
did that... i need to get it all bck together n upload to show yall what it does....
hard to explain. i can drive it around fine jus cant get on it or even build boost.... right when the car starts to build boost it jus takes a crap, like i took it out of gear or the wastegate open (power dump)
1 - 4 of 4 Posts
