OBDII USB scanner/realtime info
1161 Views 2 Replies 3 Participants Last post by  inmydream316
This is an ELM OBDII interface. You plug it into your ODBII port in the RSX, and plug the USB cable into your laptop. Free software available on the web interfaces with your car, and you can check/clear engine codes, and monitor data live.
25 dollars shipped. You can run this thing while you are driving and monitor info
Demonstration photos of software
At the very least, its an inexpensive code-reader, and most of the software will not only tell you the code, but give a detailed description
1 - 3 of 3 Posts
I was wondering if this can be used to program a key or reset the SRS computer.
I heard dealers are using OBDII port to do these things.
dealer put OBDII to key-match but completely different program. it cannot be done. unless we somehow steal that shit from dealer.
1 - 3 of 3 Posts
