Status
Not open for further replies.
#3
Apr 1, 2010
imbest123 484
tallok 262
DJCarbine 260
TireMeltingRSX 195
spectre 166
na_rsx 97
krystar 87
Koneko 70
Zephere901 64
JayPee_inc 62
melo_1981 29
fretburnr 24
germs 16
eskribble 15
chicagorsx-s 6
BlkCivic 5
thebluedc5 4
VSmotorsports 4
#4
Apr 1, 2010
imbest123 484
tallok 262
DJCarbine 260
TireMeltingRSX 195
spectre 166
na_rsx 97
krystar 87
Koneko 70
Zephere901 64
JayPee_inc 62
melo_1981 29
fretburnr 24
germs 16
eskribble 15
chicagorsx-s 6
BlkCivic 5
thebluedc5 4
VSmotorsports 4
:giggity: i win
#11
Apr 1, 2010
So the place I ordered my vacuum block materials and oil restrictor etc... their warehouse is in chicago.
Free next day shipping
wtf is an oil restrictor? i just ordered my heatwrap (got urs too), vac block and spark plugs. i was gonna get the 1/8" NPT fitting off here but i just couldnt justify spending $10 on a fitting :rotfl::rotfl::rotfl:
#15
Apr 1, 2010
Chinese turbo + oil restrictor = long life
The chinese turbos are known to wear the oil seals because K20 puts out like 80+psi @ wot
The turbos require 5-40psi
Thats the number one cause of chinese turbo death lol
Oh, and I ordered 1/8NPT fittings from the place. It was 7 bucks for a pack of 10
http://www.mcmaster.com/itm/find.AS...hDtlLink&fasttrack=False&searchstring=5346K61
0
#7
Apr 1, 2010
you forgot 3 and 4, you are the dumbest asian on the planet
#29
Apr 1, 2010
How many jack stands do you have Yuliang?
Check my ninja edit for a working link to the hose barb fittings lol
I swear all those vacuum blocks are just riced out versions of commercial vacuum manifolds
:rotfl: that's why Andrew wants em.
0
#36
Apr 1, 2010
evan, what hose size id shud i get for the 3/8 fitting?
#38
Apr 1, 2010
I'm assuming 3/8 hose for the 3/8 fitting
I'm also assuming 1/8 hose for the 1/8 fitting
Its pretty standard to have the same size hose go to the fitting
I know all my BOV/WG vacuum lines are going to be 1/8
The 3/8 is the feed for the vacuum block, and I think the brake booster/PCV hose is 3/8
0
#47
Apr 1, 2010
I'll break it down
From here on, anything before the throttle body is "compressor"
Anything after the throttle body is "manifold"
WG goes to compressor
Vacuum block goes to manifold, and feeds :
BOV
Boost gauge
My WG has 2 ports, one for normal operation, the other is supplimental for a boost controller
The port on WG for boost control will go to
Boost controller, which goes to
vacuum block
#48
Apr 1, 2010
makes sense but ill still let u do it since ill get mixed up :rotfl:
0
#49
Apr 1, 2010
To be honest I have no idea how internal wastegates are regulated
I took apart my external so I know exactly how it works, and tested it with a vacuum pump
I am pretty sure your wastegate in normal operation will be connected to compressor
The more pressure it sees, it will eventually overcome the spring and open the flapper allowing exhaust bypass
With a boost controller, you can limit how much pressure it sees and in turn ave the flapper open later, allowing for more boost
This is just theory, I never really played with an internal wastegate
#50
Apr 1, 2010
does this make sense to you?
the port 1 goes to the wastegate actuator, then the other side (port 2) goes to a main vac source. The middle is the filter/foam element.
this means port 2 just goes to the block? seems pretty basic if thats the case lol
#51
Apr 1, 2010
When they say main vac source, do they mean pre or post throttle body lol
1
#53
Apr 1, 2010
Diane just got a job at target, who wants discounts lol
#56
Apr 1, 2010
dam i used to always shop there
assistant manager lol?
1
Status
You have insufficient privileges to reply here.
