1 - 20 of 498 Posts
I know we have a drag racing section but that isn't being updated. I would like to see how the turbo rsxs are doing out there in the 1320. If there is already one here please lock this thread. A slip or vid would be needed to make the list.
Here is the style I want you to send it in:
[email protected] - Username /State / Motor Type (k24,k20,k20R, Etc. + Modifications) / Forced Induction Setup / [email protected] / Weight w Driver / Tire Size/ Tranny
Example:
[email protected] - blueshark123 / NJ / K20 86x86, built, 9:1 / Full-Race Stage 3 GT / [email protected] / Removed seats and spare tire / 24.5x8.5x15 MH Slicks / stock ep3 5-speed
9.00-9.99
[email protected]/MD/ 2620lbs full race mani/ k24/67mm/[email protected]/ full interior minus back seat and airbags/24.5x9.0-13mt/ ppg 1-4 Dogbox
9.965 @ 155.61 - '02whitetypes / MA / K24/K20 89mm, 10.0CR, Full Race manifold w/Borg s400 67mm turbo / 32psi / 2600 lbs / stock axles / 25x8.7x13 M&H Slicks / PPG 1-4 Dogbox w/4.76 FD and Quaife LSD.
10.00-10.99
[email protected] - PYRSX /TX/ 87.5x86 K20/ S372 Liquid to Air / 650+ 26 PSI / 2600lbs /26x10x15 MH Racemaster/ PPG 1-4 Dogbox w/ quaife
10.066 @ 149.13 - '02whitetypes / MA / K20 86.5mm, 9:1CR, stock sleeves, stock cams, stock axles / Custom sidewinder setup w/Borg s400 67mm turbo / 33psi / 2660 lbs / 24.5x9.5x13 M&H Slicks / EP3 5-speed w/PPG 1-2 Dog and Quaife LSD.
[email protected] - KeseK24RSX / NC / KMOD Stg.3 K24, 11.0:1 / KMOD St.5 Turbo Kit(PTE 6266)/ [email protected] / Removed spare tire / 24.5x8.5x15 MH Slicks / KMOD Built RSX 6-speed Trans(stock gears/ratios w/ 5.06 final)
[email protected] - KeseK24RSX / NC / KMOD Stg.3 K24, 11.0:1 / KMOD St.4 Turbo Kit(PTE 6266)/ [email protected] / Removed spare tire / 24.5x8.5x15 MH Slicks / KMOD Built RSX 6-speed Trans(stock gears/ratios w/ 5.06 final)
10.4 @ 147.20 - Htownxjoey / TX / K20 87 mm, built, 9:1 / Peakboost Manifold FP Hta86 /stock 5 spd/ [email protected] / 3100lbs/ 24.5x8x15 Mickey Thompson Slicks / stock ep3 5-speed
10.460 @ 141.569 - rbarbera75 / NM-5300FT Elevation / k20 87mm - Brian Crower Stroker Kit / Full-Race Stage 3 GT / [email protected]/Almost Fully Stripped/ 26x8.5x15 MH / RSX-5spdBase
[email protected]_rsx/Md/k24 Frank/PPG 1-4 base 5th tsx6th/ 9:1 comp/ Borg S366 .88ar/ 733/540 at 27psi/ 13" rims 24.5" slicks/ full weight plus cage minus Ac and ps
[email protected] - KESEk24RSX / NC / K20/K24 87.5x99, built, 11.1:1 / KMOD Custom Turbo Kit(55mm Turbo / [email protected] / Removed seats and spare tire / 24.5x8.5x15 MH Slicks / KMOD Type-S 6-speed Trans
[email protected] - JO TECH/ Puerto Rico/ CP 9:0:1 Crower rods/Custom turbo kit pt-67/ [email protected]/ 26x10 / rsx type s tranny w/lsd
10.9 @ 135mph - K24a2rsex/ FL/ K24a2 sleeved 87mm bore 11:1/Proven Power sidewinder turbo kit w/ pte 6262 / 689whp @ 25psi/ full interior car + 230lb driver 24.5x8x15 MH slicks/EP3 5spd w Spool LSD
[email protected] - RSXING AZ / AZ / k20 built 86mm / Full-Race Stage 3.7 GT / 689 [email protected] psi/ 2900/24.5x8.5x15 MH Slicks/ ep3 5-speed with LSD
11.00-11.99
11.1 @ 133mph- DC5 BABY / FL/ K24a2 87mm bore 11:1/Proven Power sidewinder turbo kit w/ pte 6262 / 689whp @ 25psi/ full interior car + 230lb driver 24.5x8x15 MH slicks/EP3 5spd w obx LSD
[email protected] - IKON671 / AZ / k20 built 86mm / Full-Race Stage 3 GT / 650whp @ 30psi/full-body with spare tire and all/ 24.5x8.5x15 MH Slicks/ Stock original 6speed and still kicken!!! with quafie LSD
[email protected] - 1xxxrsx / ny / stock k20 / cybernation turbo set up w/greddy intercooler kit / 450 whp 17.5 psi
Q16 / 2740 lbs / 24.5x8.5x15 m&h / stock ep3 tranny / morris tunning
[email protected] - K20turbo / UT / K20 86x86, built, 9:1 / Custom kit T3/T67 H.O / [email protected] / 24.5x8.5x15 MH Slicks / stock ep3 5-speed
[email protected] 131 - EncoreRSX / CA/ K20 built 86mm, 9.1/ PEAKBOOST Gt35R/ [email protected]/ 3000lbs/ 24.5x8.5x15 MH slicks/ Stock Ep3 5-speed
11.57 @ 123 - WooTIHaveATypeS / Bandimere Speedway 5,800ft Elevation, CO / Stock Block / PPG Gears Built Trans w/ Quaife / PeakBoost GT3582R Turbo Setup / 440whp & 330wtq / 2,850lbs Full Weight
11.685 @ 126.63 - infumis / Canada / k20a2 / stock sleeves 9:0:1 / fullrace stg2 gt30 / 6spd w/quaife / 24.5x8" slicks / street tuned 94 oct / full interior / MT 24.5x8 slicks / 6 spd with LSD
11.7 @ 117 - lightbulb /06 type s/ stock motor/ stock tranny with mfactory lsd / go-autoworks turbo kit/ slicks 24.5x8.5/ 445whp @15psi
11.705 @ 122.80 Jamesl85 / MN / stock k20z1 / RevHard log manifold pte 5831, e85 / 22+psi / 2940 lbs with driver / 225-50-16 Hoosier Drag Radials / Gear-x 1-4, Gear-x 4.0 final drive, MFactory LSD, Insane Shafts 1000hp axles and halfshaft
[email protected] - Some-1 / PR / k20 built 86mm / Custom (Log style) / 504whp @ 20psi (93oct) / full-body / Hoosier Drag Radials / Base 5speed with quafie LSD
[email protected] - MELLO / NV / K20A2 86mm stock / Peakboost GT35.82 / 440hp @ 16.5psi / 3000lbs / 24.5x8.5x15 M&H Slicks / stock 6 speed wavetrac lsd
11.86 @ 116 / JayRSXS / TX / K20Z1 86 MM Stock / Peakboost GT3076.82 / No Dyno But Pushing 13 Psi / Full Weight (Including Spare, Jack, Floor Jack, Tool Box, and Sub) / M&H Slicks 24.5x8.5x15 / Stock 05 Type-S Trans
[email protected] - Anorexorcist / CA / K20 stock / Peakboost GT35 91 octane/ [email protected]/KTeller 3"/ ~3000 lbs / 24.5x8.5x15 MH Slicks / stock DC5 6-speed/ full interior
[email protected] - osusantacruz / OH / K20 86x86, built, 9:1 / slowmotion motorsports custom gt40r / [email protected] / ~3000 lbs / 24.5x8.5x15 MH Slicks / ppg gears
12.00-12.99
[email protected] - Fade2black/ CO/ K20A2 86x86, built, 9.0:1/Treadstone PT67/ (450WHP/14psi/pump)(500whp/14psi/E85)(610whp/22psi/E85)/2575/24x8x15 M&H/ PPG synchro set
[email protected] - Guardian / NV / k24a1/k20a2 87x99 9.6:1 / Cybernation 50trim / 350whp 321wtq 16psi / ~3000lbs / 24.5x8.5x15 MH Slicks / ep3 5-speed, quaife
[email protected] - Dragncivic /CT / stock k20z1 / greddy kit / [email protected] on racegas / heavy as hell...lmao im fat / 24.5x8.5x15 MH Slicks/ stock tranny with quaife
[email protected] - archull / Baton Rouge, Louisiana / Stock motor /Peakboost kit gt3076 / [email protected] / M&H 24.5x8.5x15 slicks / stock 06' Tranny w/ CC Stage 4 clutch
[email protected] - Monjarassi /TX / (k20/k24 forged vteckiller/ fabworx sidewinder,PTE6266, e85 / [email protected] / 2391 / 255/50/16 555R dr / Oem ep3 5spd, twin disk, mfactory lsd, insane shafts
[email protected] - JSeoul / PA / stock k20z1 / GReddy kit / 310whp 242wtq / 24.5x8.5x15 MH Slicks/ Quaife LSD
[email protected] - ttxi475 / MN / K20A2 Stock, / eBay .57 Trim / E85 12 psi / Full Weight / 225/50/16 All Season Tires / Stock 6-Speed
13.00-13.99
[email protected] - premiumRSX / FL / K20 86.5x86 built, 9.8:1 / Rev Hard SC6176 / ?HP @ 16psi / Stock Tires / Base 5spd / Full interior with other crap too
[email protected] - Jeff122886 /MA / Stock Block / GT2871R / Greddy manifold / 3" turbo-back exhaust / 750cc / walbro / rbc / dont know power, on a partial street tune from mag but was at 8psi with creep starting at 7.2kish and hitting 14-15psi at 8k / 3016 lbs / stock rims with almost bald kumho's / stock tranny and CC4
13.3 @ 111 -K20 on b00st s0n / FL / stock k20a2 / custom treadstone, synapse 40mm wg, turbonetics t3/t4 turbo 3'' dp, ex., rbc / 318whp @ 14psi street tuned by K_20 / Full weight / Hoosiers 245/45/16 / stock k20a2 6 speed
[email protected] - hopupimports / Las vegas Nevada/ stock k20a2/ 60-1 .82 hotside stage 5 wheel, rev- hard mani, custom downpipe, greddy FMIC, kpro, cc stage 4, custom 3" exhaust, street tuned by supertuner/ 16psi on 100 oct/ Nitto 555r's drag radiels/ ?
[email protected] - EBP-RSX-S / MA / Englishtown Raceway Park, NJ / stock K20A2 / GReddy T517Z / [email protected] / 2978lbs / 225/50R16 Hoosier drag radials / stock 6-speed
13.448 @ 107.12mph - soccerman002 / Virginia Motorsports Park / Stock K20A2 / Greddy Turbo Kit / 244.5whp @ 7psi / Stock Car + 180lb. Driver / 16" Dunlop FM901 Street Tires / Stock Tranny
[email protected] - adh365/ OH/ Stock K20/ HKS GT2835 Kit/ [email protected]/ rsx type s/ street tires
[email protected] - noobDC5yo /Florida / K20A2 Stock internals/ Greddy log style mani turbo kit / ~300hp @10psi / stock weight+150lbs driver+tools and miscellaneous stuff in the car / street tires, 225 / rebuilt tranny by Synchrotech Transmissions
[email protected] - Chardmax / Quebec /K20z1 87mm bore built bottom 8.61:1 built head with BC rbc man/ Custom turbo kit sidmount manifold Gt3076r Partially tuned very partially / estimated 260 whp @ 10 psi / 2813 lbs / 215/45/17 toyo T1r street tire / K20a3 5 speed Type-r
[email protected] - petah / Grand Bend Motorplex, Ontario, Canada / ? /Greddy T517Z / Never dynoed but it was on test pipe and stock exhaust ick / ? / Street Tires / ?
Discussion Starter #2 (Edited)
Here I'll add a few but dont have all the information. Please reply with the information and Ill add you to the list unless you dont want to have that information displayed just post up and Ill add whatever I shown. This is what I found with a quick search.
[email protected] - PYRSX/ TX / ? / ? / ?/ ?/ ?/ ?
[email protected] - RSXING AZ/ AZ / k20 86mm / Full-Race Stage 3.7 GT / ?/ ?/ ?/ ?
[email protected] - IKON671/ AZ / k20 86mm / Full-Race Stage 3 GT / ?/ ?/ ?/ ?
[email protected] - importracer3560/ AZ / k20 86mm / Full-Race Stage 3 GT / ?/ ?/ ?/ ?
11.65 @119.14 - '02WhiteTypeS/ NY-MA / k20 86mm / P2R log manifold SC61 / ?/ ?/ ?/ ?
[email protected] - rbarbera75/ ? / k20 87mm / Full-Race Stage 3 GT / ?/ ?/ ?/ ?
[email protected] - Mello / NV / ?/ Peakboost GT35R / ?/ ?/ ?/ ?
[email protected] - Fade2black/ CO/ ?/ ?/ ?/ ?/ ?/ ?
EH EH EH EH EH EH EH EH
petah
13.886 @ 99.92 / Grand Bend Motorplex, Ontario, Canada / Greddy T517Z / Never dynoed but it was on test pipe and stock exhaust ick / Street Tires
stock motor/6speed .. i should have new track time next year when i get to it.
11.88 @ 120 mph
11.65 @119.14 - '02WhiteTypeS/ NY-MA / k20 86mm / Rev-Hard SC61 / ?/ ?/ ?/ ?
[email protected] - Mello / NV / ?/ Peakboost Stage 3 GT / ?/ ?/ ?/ ?
mine isnt in there :crying:
The Architect™
I am kinda embarrassed to post mine, lol
I have slicks on the way so I will redeem myself shortly
[email protected] - archull / Baton Rouge, Louisiana / Stock motor /Peakboost kit gt3076 / [email protected] / street tires / stock 06' Tranny w/ CC Stage 4 clutch
The Architect™
Yeah I know you weren't too happy with your times so I didnt post them lol.
lol, i will update them after the 16th when I get my slicks on. I still won't be fully tuned yet because I have to get another set of injectors, but hopefully a can shave a bit more than a second or so off, lol
Zack Killa
:rotfl: :rotfl:
UnderPressure
13.88 sec @ 110 mph - Chardmax / Quebec /K20z1 87mm bore built bottom 8.61:1 built head wiht BC rbc man/ Custum turbo kit sidmount manifold Gt3076r Partially tuned very partially / estimated 260 whp @ 10 psi / 2813 lbs / 215/45/17 toyo T1r street tire / K20a3 5 speed Type-r Lsd best of my 4 run i did for the first time of my life this summer
Retired OG
going for different numbers and possibly a new setup next year...but definately going to improve on track times
Reactions: blueshark123
11.1 @ 136mph
[email protected] - RSXING AZ/ AZ / k20 86mm / Full-Race Stage 3.7 GT / 689 whp @ 32 psi/ 2900/24.5x8.5x15 MH Slicks/ Stock original 6speed with open diff.. (this pass was made @ 25psi in the AZ summer heat:) )
[email protected] - IKON671/ AZ / k20 86.mm / Full-Race Stage 3 GT / 650whp @ 30psi/full-body with spare tire and all/ 24.5x8.5x15 MH Slicks/ Stock original 6speed and still kicken!!!:beerchug: with quafie LSD (this pass was also made on 25 psi in the AZ summer heat:) )
made my changes
1 - 20 of 498 Posts
