1 - 20 of 21 Posts
BOOST
I just got finished talking with my uncle about the oil he sells, Motul. I told him I would have the turbo in soon and he offered the 8100 Motul oil to me, but my question is, its recommended to change oil every 2000 miles with turbo.... but my uncle said with motul i wouldnt need to do it so often, my question is how often would you recommend with motul 8100?
Thanks.
10w 30 Mobil1 synthetic and change ur oil every 3,000 miles. Lemme know when u get the turbo installed cuz It's a beast.
Thanks.
ALWAYS!!!!!!! Always change your oil between 3000-5000 miles.
i always told my friends with bolt-on turbo kits to change oil every 2500 period. and sooner if you go with those cheap oils (non syn)
We recommend changing your oil at about 2k miles. This is especially important with stage II cars.
Because the Turbocharger feeds into the oil line of your engine sucking up a lot of it. The turbo spins between 10,000 to 15,000 RPMS constantly. That's a whole lot of friction that needs a whole lot of lubrication.
hes right
because the car wasnt designed for a turbo, its more abusive to the liquid per say, than a fact turboed car.
some guy
would u need to change the oil as often with a supercharger too?
The amount of heat the turbocharger soaks up from the exhaust gas is huge, and it would be wise to change your oil often so you maintain its viscosity to help fight friction. Also, when you run rich, your oil gets dirty fairly quickly. Some of the un-burnt gasoline gets into the engine oil and fouls it up, and that makes the oil less effective. Unless you have 0 blow-by, this is going to happen continuously.
I would say every 3000 miles and a good filter would do the engine wonders. You don't even need to use synthetic, just oil that's thick enough to take the abuse.
Just recently I went to get my oil change at Jiffy Lube; Of course I brought my own oil (Mobile1 10w-30). Nehow, I got the chance to speak with an attendent who was asking about the turbo. Our conversation lead up to comparing oils. He highly recommended Royal Purple and Penzoil. Throughout the whole conversation he was basically putting down Mobile 1.
Aasyranth said:
Is it any different for water-cooled turbos? Or would you still want to change every 2K? That's pretty much as close to a factory turbosystem as one can get.
Remember, that poor turbine spins at over 100000 rpm.......
I would make sure I feed it the best oil possible.
Water-cooled turbochargers improve reliability, but the oil carries deposits and dirt so it still needs to be changed regularly.
Cn
I got big question about the cybernation stage 1 turbo.
What is its potential of the stage 1 turbo on a type S if i only got the stage 1 with pistons and rods because i am planning to get one sometime soon?
Also if i am planning on running at least 300 whp what would you recommend on me getting pistons? rods? flywheel?
With the GReddy kit, what oil is recommended? 5w-30 or 10w-30? I use Mobil 1 synthetic 5w-30 now and change every 5000. I plan on using Mobil 1 synthetic but change every 3000 after I turbocharge.
I would say that with a turbo, 2000 miles is a definite oil change point. Earlier would be better as I just changed my oil after 1500 miles and it was pitch black. I use mobil 1 10w30
1 - 20 of 21 Posts
