1 - 20 of 37 Posts
2drrsx
hello fellow CRSX please help me also tks in advance for your thoughts
car type 2005 acura rsx type s k20z1
ok so i got this oil leak it is coming from the metal plate area between my tranning and my engine. it is also coming out of a hole located right above the passenger side axle
what i researched people saying it was the passenger side transmission seal. i was going to do my clutch so i decided to get both the driver side and passenger side axle seals and rear main seal while im at it just in case.
just got done changing the two axle seals and rear main seal and my clutch but... its been 3 days since then and my same oil leak is coming back. i cleaned everything very well before i put any of the new parts in... i have some pictures of what it looks like as of today down below.
please give me any thought of what you think it can be... i tried to smell the oil to see if its coming from the transmission or the engine but the oil is kind of odorless or maybe my nose is not working but again please let me know
p.s. sorry for the crappy spelling im trying to describe everything quick and ask any questions you want in order to solve this problem
update:
ok i did all of the valve cover gaskets # 1,2,3,4,15,14 in the picture above. it is not leaking anymore from the valve cover BUT it is still leaking somewhere below because i still have the exact same leak and NO my head gasket is not bad and my block is NOT warped there is no oil leaking anywhere from the beginning of the head to the top of the head.
i looked very close and it seem like it could be leaking anywhere below around the block area mainly inside the transmission casing could even be the transmission leaking.... im narrowing it down to the oil pan...??? any more guesses? please help
Final update Problem SOLVED:
it was leaking at the weirdest spot every the bolt that connects behind the block that is located behind the flywheel. decided to take it off and upt some taflon tape on it and bam no more leaking oil/
heres a picture its number 3 in the picture
Start looking up high and work your way down low. It is best If everything is clean then the leak will be more pronounced. U check ur valve cover gasket yet, if it does leak it usually will be one of the rear corners. Maybe not your vtec Silinoid but check anyways. My guess would have been the axle-seals, then oil pan.
might of been oil filter when changed oil, oil pan bolt, might need to put silicone on vc gasket at points, cover for chain tensioner, head might not be mated right to head, and last but not least rear main seal could be bad...there you go all possibilities..lol
2drrsx
Discussion Starter #4
Tks guys/girls if anything I don't think it's coming from the passenger side at all but I'll check anyways you'll never know it's not the rear main seal because I just changed it... but what it does look like is maybe it's coming from the oil pan I'll do that and see where that leads me... I was reading this one post on google and they said that some people have to change their passenger side transmission seal more than once and they said that the reason to that's is because possibility that the differential bearing is probably going out I'll post up the link to that later let me know what you guys thing about that
i would honestly check the valve cover on the tranny side your supposed to put grey silicone there where the sensors are but on the gasket...i had a rsx z1 block and it had a oil leak on the mateing part of the block to head...
Check your valve cover gasket, my car looked like that underneath and i checked the vc gasket and that was my problem, i bought a oem gasket off here and put it on and tourqed all the bolts to what they needed to be and had no problems since, i beleive the tourqe specs are 7.2 or 7.5? correct me if im wrong, and there is no need for honda bond if its tourqed correctly either.
your wrong!!!!!!!!!!!! lol jk
everytime i've got a oem valve cover off they always put silicone where the chain cover meets head and side where sensors are(4 spots)..
2drrsx
Discussion Starter #8
Just checked the area of te valve cover u guys told me it's still good no leaks anywhere to be found on the valve cover at all and the leak is consistent so if there was any leak I would be able to spot it easily please lmk if there's anything else I should check
is it a big leak?? or do you think it could be the oil left from filter after oil change??
2drrsx
Discussion Starter #11
I don't think it's the oil left from the oil filter because I did my last oil changes months ago and about how much oil am I losing not sure but I can say that I park in the garage and every day the puddle gets a little bigger not too big I say right now it's about 1 inch but because I just had this problem before and when I did open my transmission oil was everywhere
sounds like the head might be leaking where the motor mates to block if it persists heavily on tranny side......you changed the rear main seal right?oil pan had any work?
2drrsx
Discussion Starter #14
Yes I already changed the rear main seal and no it's not leaking from the head gasket I looked all around especially the corner where I took the picture to see if it was coming from up above but like I said I had this issue before and the whole inside of my transmission where my clutch is at is all oily donno where it's coming from maybe from the inside then peaking out or somewhere in The outside leaking in lmk any thoughts
2drrsx
Discussion Starter #15 (Edited)
Hey I looked at ure thread and the pictures looks just like mines exactly u said that u replaced the two bolts on the shifter mechanism what exactly r u talking about any pictures would really help tks if u can't get pictures a diagram from oemacuraparts.com could help with the description tks also did this solve your problem?
This is worst case scenario, but there were some K blocks with casting issues...
i agree i have a z1 block that i just built had the same issue oil went down from head and block. :chillout: :shakehead luckily i spun a bearing on 700 miles loss of oil pressure maybe my issue who knows, although i was on s2 cams and 50 shot of nos lol.
sucks guys but if you want it to stop i would look at buying a new block or just taking it apart tell machine shop ur issues..have them take it from there..
i took the time to take pics so you could see your issue under the head and gasket..peep it..
k20z1 block rsx-s
k24a4 block i have on ice lol
2drrsx
Discussion Starter #19
Hey that's a good though about the head leaking I was just wondering if u had oil inside your transmission casing like where the clutch is at? Because when I opened my transmission to change the rear main seal the first time there was oil everywhere inside there it was moist but not to the point where it was watery
2drrsx
Discussion Starter #20
problem possibly solved so i took into consideration that maybe it might be leaking from the head gasket and as i stuck my head inside my engine bay to look between my head and block i noticed oil yes!! and no!! well i kept looking up and basically found my problem it was like what you guys said from the beginning my valve cover gaskets were leaking i took some pictures just in case any one wanted a visual.
my question now is... ok i know i want to buy a valve cover gasket set, and maybe the O rings that goes where those sensors go into the head basically the ones in the picture that you can see. anyways what else should i buy while im at it? any gasket reccomendations my car has about 110.xxx and i am the second owner and from what i know none of the gaskets on the engine have ever been changed except for the ones i stated and i did the head gasket a while back maybe 20,000 miles ago but just looking to do gaskets that are around there
ps not 100% sure this will solve my problem i will give you guys feed back as tiime goes by
1 - 20 of 37 Posts
