It's leaking around the gasket all the way around pretty muchHow do u think the head gasket started leaking? Was there recent work done? Sorry for your luck
Are you looking at the head or the valve cover? If your head gasket was leaking, you would likely be experiencing misfires and over heating. You'd also probably have coolant mixed in with your oil. It's possible for a head gasket to leak around a cylinder or two, but I've never seen it leak all of the way around.It's leaking around the gasket all the way around pretty much
Is it Possible for the head gasket to be leaking oil but it’s not mixed with coolant and it doesn’t over heat?Are you looking at the head or the valve cover? If your head gasket was leaking, you would likely be experiencing misfires and over heating. You'd also probably have coolant mixed in with your oil. It's possible for a head gasket to leak around a cylinder or two, but I've never seen it leak all of the way around.
I don't think it's possible to have one leak without the other, but I've also only ever dealt with this one time. Best way to approach this is to clean up the engine bay with a degreaser and start poking around the block. I use Simple Green on mine. If you can get the car to a shop, you can have them do a leak down test.Is it Possible for the head gasket to be leaking oil but it’s not mixed with coolant and it doesn’t over heat?
