1 - 2 of 2 Posts
So I noticed oil spill a couple of days ago couldn’t find from where then boom I saw it my oil pan was spilling so much oil it got on the serpentine belt and went everywhere causing so much smoke and also my altenater went out . I have never worked on a car hands on but seeing as money is tight I took on the challenge and successfully swapped out the altenater but I am having trouble removing the oil pan to replace the gasket any help would be appreciated
Been Around for a while
Sorry to hear, if you search you should be able to find the solution. Basically you will remove the rear motor mount bolt (and motor mount if needed / not required) and drop the sub frame to remove the oil pan.
1 - 2 of 2 Posts
