1 - 11 of 11 Posts
Must...stop...modding!!
Alright, I was about to buy a 5Zigen fireball, but the price jumped on me suddenly @ modacar, and come to think of it, I am pretty tired of cops harassing me, so I was thinking....would the stock muffler welded up to 2.5 inch piping do me any good? From what I have heard, the stock muffler isnt where MOST of the restriction is in the exhaust system...so if i got some 2.5 inch piping which allowed more flow....and welded up the stock muffler, I could retain my stock look, (although i dont think it will sound stock, but I am guessing that it wouldnt be THAT loud) and the sacrifice of ponies wouldnt be that great. Dont get me wrong, I love a great sounding exhaust, but Im tired of having to watch my ass and shift at 2.5K whenever a cop is within a 4 car radius of me. So what do you guys think? Does it sound like a good idea? Would a really lose that much power with a stock muffler mated to the 2.5 inch piping? Anyone tried this and have anything to say about it?
I'm currently running the Magnaflow piping (2.25") with the stock exhaust. I love it. Lots of low-end torque, and sounds just like stock.
As part of my quest of trying different things with my exhaust setup, I removed the magnaflow resonator (which has a 2" inner diameter aprox.). The car felt so slow (magnaflow/no resonator/stock muffler) and sounded horrible, so I went back the next day to de mufflershop and welded back the resonator.
Do not go for a 2.5", thats too much for a n/a car. Go 2.25" all the way to the stock muffler (including a 2.25" (inner diameter) resonator of course).
If you plan to boost, then you can maybe try the 2.5" piping, but use a 2.25" resonator until you boost your car.
I measured a loss of 1 hp by replacing the magnaflow muffer with the stock one. However this was done using a PDA Dyno, so it may not be that accurate at all.
I would really go for the custom 2.25" piping, 2.25" resonator and stock exhaust. However make sure to find a good muffler shop and that they keep the 2.25" diameter through all the piping (some thime when they bend the piping, the inner diameter is reduced by a couple of mm)
there's is a website that sell custom made piping for our cars for $200.00. I can't remember the website... anyone knows the website address?
sounds like a good idea then...however, I want 2.5 inch piping to free up some flow for my comptech race header. Try and see if you can post up a sound clip of your exhaust.....it HAS to be a little louder than stock? See if you can pull up that website too, it would help a lot. Did you also have to modify the stock muffler in anyway so the custom piping could fit? What I planned on doing was going with custom 2.5 inch piping, and I wasnt sure what kind of resonator to use. I was originally planning on using the stock one but can you recommend any other kind, say like a custom 2.5 inch resonator? Thanks a lot....peace!
2.5" is not too big for an N/A car. Also, if you're boosting--you're probably going to want to run 3". 60mm or the larger 2.5" is fine for our cars.
so ur using ur magnaflow piping and magnaflow resinator with your stock muffler right?
-Try and see if you can post up a sound clip of your exhaust.....
I'll will record some audio tonight
-it HAS to be a little louder than stock?
A bit when you step on the gas, but at idle is almost the same
-See if you can pull up that website too, it would help a lot.
I've been trying... haven't find it.
-Did you also have to modify the stock muffler in anyway so the custom piping could fit?
I modified the stock muffler to fit the magnaflow exhaust (no need to bent or modify the muffler piping, just the part where the bolts go.)
-I was originally planning on using the stock one but can you recommend any other kind, say like a custom 2.5 inch resonator?
I'm looking for a 2.25 resonator but I haven't had any luck. I want to replace the magnaflow resonator (2" or less inner diameter).
By the way, I went yesterday to the track to test the magnaflow+stock exhaust, and I got the same numbers as I did with the full stock catback.
it could be due to diferent track conditions, but just to make sure, I will try next week the the magnaflow muffler to see what happens.
Discussion Starter · #11 ·
Bump....anyone know where i can find that custom piping?
1 - 11 of 11 Posts
