u should be fine. if not just drain some more oil out. i had a freind that did this to his gsr motor and it bogged bad and ran like shit. but we just drained some more and it ran perfect
check your dipstick.........:shakeheadi was changing my oil, and like an idiot i was yacking and not paying attention to what i was doing and put all 5 qrts of oil in instead of the 4.5 its supposed to be. I drained a bit out of the pan, but i dont know how much. I think its still alittle over. should it be straight?
thanksi put 5 qts in my car after drain/fill since my first oil change. still fine here.
but its always a tiny bit above the second dot on the dipstick, which is fine.
:iamwiths: Just check it if its over just drain it a lil more and go back to check it should be fine.check your dipstick.........:shakehead
ya wut he said.... nah just check ur dipstick and drain some more until its right. :thumbsup:Your going to have to pull you engine, turn it upside down, and drain the excess oil back out.
is this guy serious lol?Your going to have to pull you engine, turn it upside down, and drain the excess oil back out.
true, but if it is slightly over it probably won't make a big difference.Overfilling with oil will cause the crank to slap the oil and will produce a lot of foam. Foam doesn't lubricate and cool as well as a liquid...
Are you serious?is this guy serious lol?
