1 - 20 of 26 Posts
[email protected]~13psi on Alcohol
as the title says, when i was datalogging today i got cel code p1166. my primary
O2 sensor shit the bed. does anyone know how much it will cost to replace this sensor? is it safe for me to drive without it for the next three weeks until i can get home to fix it? or should i try to get it fixed immediately? thanks for any help
Discussion Starter · #2 ·
bump
so i guess i should check to see if any of my wires are messed up, then replace the sensor. does anyone know if the denso sensor is as good as the ngk sensor? the denso primary o2 is $175 and the ngk primary is $300. is there any reason to go with the ngk?
both are oem....get the denso
if your calibration is in good shape, you can run without a primary o2 sensor for a lil while.
i ran with a dead primary for three weeks before i got my hands on a new one.
no sensor means it goes off whatever is in your calibration. if you know how to tune, then you'll be fine for a short while.
my gas mileage was the almost the same
less than 50 miles than normal
Discussion Starter · #20 ·
Aside from telling you to search
cuz there is 80,000 threads on o2 sensor and this code specifically...
.... www.sparkplugs.com (denso)
thanks but i had already found the sensor, i wanted to know if there was a reason to spend more money on the ngk over the denso
thanks! that's what i wanted to hear
how do you tune without an 02 sensor?
u can run it...itll eat ur cat over a long time and u get terriable gas mileage
i don't have a cat i have a RH
1 - 20 of 26 Posts
