1 - 7 of 7 Posts
I tried painting my wheels not too long ago to save money for a lowering kit and exhaust system instead, but after i sanded one wheel down I tried to apply the primer and it just didn't stick. So now i have one wheel that is all scratched from sanding it down and I am wondering if I did something wrong.
make sure they are CLEAN !! wipe em down with acitone or somthing like it before painting. KEY ! and what did u use for grit sandpaper??
I used 180 and 320 I think. Could it have been the temperature? It was like 40 degrees when I tried to do it.
Wait till it gets warmer out to paint them. I used 320, 480 and a higher grit to smooth out before I sprayed the primer when I did mine. I used self etching primer and krylon paint and everything stuck well.. But deffinitley should be warm when you do it
JDM is contagious
Anything below 50 degrees and you're going to have problems, I'd wait until it is atleast a solid 70 and let it cure for a day or so before putting the wheels on, unless you want plenty of rock chips.
I agree with the temperature thing. In cold temp paint won't dry. U want it to cure in sunlight or a heated room of some sort. Don't use blow dryer. Use those portable heater out of Walmart. The heat should help cure faster. Then let it cool off a day before giving it a good wipe job to shine out the gloss. Don't use drive thru car wash for a week at the least.
1 - 7 of 7 Posts
