1 - 1 of 1 Posts
First of all I have the Acura rsx 04 mt.
My stock headlights were working fine the bulbs and high beams were working and then I got new halo lights and installed them. The driver side bulbs works just fine but the passenger side does not. So when I was installing these I had to cut some of the wires so I could connect the socket to my hid power boxes ( not sure what there called). I wired the halo lights to my parking lights. I also checked my grounds which look fine unless i missing a ground I forgot to check. After doing this my high beams work barely, when you turn them on they shut off after 3 seconds and my regular light still does not work any thoughts would be greatly appreciated. If you need pictures I will post if that helps
1 - 1 of 1 Posts
