1 - 11 of 11 Posts
on my old car...my oldsmobile cutlass, there is a pink/light brownish leak by the tire, it leaked a ton. any ideas? i know this is an rsx forum but it might be the automatic transmission fluid?
most likely, maybe PS....
Reactions: Erika
Trans fluid is normally red....
But some coolants are pink nowadays....
whats it smell like? if its sweet smelling its coolant
if it smells like..."crap" its gear oil....which means it could be trans...or it could be powersteering cuz that smells bad too
well the tranny fluid on my rx300 is pinkish so I guess it depends on brand...
997 C4S
Check your reservoirs then compare the levels again over the next few days. As mentioned, it could be ATF, coolant, PS (some PS systems use ATF).
1 - 11 of 11 Posts
