1 - 10 of 10 Posts
G
Does this look like a RSX Type S on nitrous? Here are his mods: AEM Intake
Greddy Evo Exhaust
NOS single jet wet fogger system
He didn't say how big of a shot he was running...I believe he is all bs and that this slip doesn't belong to him...
G
OK...here we go, 50 shot of wet nitrous and he has toyo proxies...so I guess this fella is using someone elses slip...
///elitist prick
K20A2 said:
I don't think so, the 60ft is the dead give away, unless he is running drag radials and got the perfect launch. The best I have done in the drag RSX is 2.321.
really? i've run consistant 2.2's with the stock tires... i have yet to hit the strip with my new tires.
:confused: :confused: :confused:
Resident Smurf
Still, a 2.0 60' in an RSX is highly unlikely. If anything, the nitrous would result in a higher 60' time if he's spraying off the line. 60' times are solely dependent on the tires and the driver. Anything 2.3 or under is good.
yeah my traps were 96.55 last year when I ran a 14.4....and my 60ft's never dropped below a low 2.2 with lsd and a act clutch.....honestly that slip looks like a awd car(wrx or DSM) with minor bolt ons
Internet Crack Dealer
jdkindle said:
I would say he is using a different time slip - compare to some of these numbers;
http://forums.clubrsx.com/showthread.php?s=&threadid=21107
On a 50-shot, he should run in the 13.8 range, but with much higher traps and 2.2X 60 fts
Hey Chris - if I ever make it up there, can I make a pass or two in the DragRSX to see what I can do?
Maybe, but it is really starting to be built around me so you may not fit in it :D.
OK guys, take note of this - as long as I can fit I can make my passes (maybe) :spin:
So Chris, do I need to beef up or slim down? Either way it sounds exciting and hope you can put the RSX on the map.
:thumbsup:
1 - 10 of 10 Posts
