1 - 12 of 12 Posts
Hey guys, my car needs a good detail. I plan on using meguirs NXT wax for the first time. Can't wait. Anyways, is it neccesary to polish before you wax it with NXT or does the NXT have enough glaze and gloss? I plan on using the meguiars pro mirror glaze, if I need to. Thanks.
jstn said:
make sure to claybar before anything. it wont hurt to polish before nxt.
very very noob question.....what is a clay bar, and what does it do???(i've seen them....but never used them...or know what they do) :confused: :yawn:
okay i did search, and found out,, but i need to find out something else...when useing claybar,,....first wash the car, and use claybar with soapy water....than wax?? :confused:
Wash the car and dry it, use the lubricant that comes with the claybar to provide a medium to help the claybar slide across the painted surface, and then re-wax.
Premium Member
I don't dry after claybarring because Zaino calls for a mix of water and wash soap for it's lube. I just make the lube a lil more concentrated and use the remaining water to balance it out.
If it calls for a quick detailer lube, you may want to dry.
Also, wash a 2nd time after claybarring since it will leave some residue.
Wash
Claybar
Wash Again
Dry Car
Polish
Wax
You don't necessarily have to polish the car before waxing. You would polish if you were trying to remove light swirls or such. It does help out to bring up the shine, but you should Polish your car like twice a year. Just wax like once a month to keep it up.
The key to any good detail is Prep Work, if you prep isn't any good, your results will suffer, simple as that, so take your time.
Discussion Starter #8
Well I like to make my car look the best, but I think I will go ahead and use Meguairs mirror glaze polish, and then use NXT.
I wash my car first w/ the NXT car wash, then dry. I apply a coat of the NXT Tech Wax, and wipe off. Both the NXT Tech wax and spray wax give the paint a very smooth and glossy finish.
i ❤ macro.
Tips on claybarring:
http://forums.clubrsx.com/showthread.php?t=155279
NXT has some *mild* polishing properties even though it's not a polish. It does seem to do a good job at covering up and perhaps removing some fine swirl marks. I would still use a polish before applying NXT if you have some troublesome scratches and if the paint still feels a bit rough after a claybar.
Discussion Starter #12
Yeah, good point eternalblue. You will get better results if you clay, polish then wax.
1 - 12 of 12 Posts
