1 - 4 of 4 Posts
My 02 rsx w/ a k24a2 power steering has never worked and when we tried to put fluid in it for thr first time and started to turn the wheel back and forth , the reservoir built up pressure and shot my cap out of the hood with fluid going all over my car if anyone has any trouble shooting help or answers to what could fix my problem it would be great , I have access to another power steering pump just didnt wanna bother if I can somehow fix this one.
When you did the swap did you put on an rsx pump or a tsx pump? I am not sure that it matters.
Vaginal Lubrication Tech
did you try bleeding it with the reservoir cap on?
I usually fill the reservoir half way. then i hold a rag over the top of it, with the cap off, and have someone start the car and move the wheel back and forth. Once its bled i top off the fluid. and cap it
or try this
How to bleed Honda Power Steering systems
1. Do NOT start the engine until the system is fully bled, doing so may cause damage to the power steering components. Pump internals are metal to metal so any air in the system can cause metal to metal contact and resulting damage.
2. Raise the front wheels off the ground
3. Turn the steering wheel fully to the RIGHT
4. Fill the reservoir to the “full cold” level & leave the cap off. Use only Honda PSF-S fluid. Do NOT use automatic transmission fluid as transmission fluid does not contain the same friction inhibitors/additives and tends to breakdown and overheat. The use of transmission fluid will VOID the warranty
5. With an assistant checking the fluid level, turn the steering wheel slowly and smoothly lock to lock until the level drops in the reservoir. If the fluid level does not drop no fluid has moved through the system, this indicates an air bubble in the reservoir or pump. Until this bubble passes no fluid will circulate through the system.  On systems with coolers you may need to cycle in excess of 40 times  Do NOT turn the steering wheel fast as this will cause the fluid to overflow the reservoir, trapped air may cause the fluid to overflow. Thoroughly clean any spilled fluid so you can check later for any leaks
6. Check the fluid constantly to ensure proper level and that no bubbles exist.  If you see any signs of bubbles recheck all hose connections then repeat the steps above.  The fluid level should be steady
7. Disable the engine from starting  Crank the engine several revolutions, if the fluid level drops there is compressed air trapped in the system, repeat the above steps until the fluid level remains stable.  If the fluid foams while cranking wait at least 10 minutes or more until dispersed air has time to accumulate and purge through the reservoir.
8. Continue to repeat the steps above until the fluid level remains constant and no air bubbles are visible.
9. Now start the engine and check that the fluid remains at level and stable
10. Reinstall the reservoir cap
11. Return wheels to centre and lower wheels to the ground
12. Run the engine for two minutes and turn steering wheel in both directions
13. Do NOT hold the steering wheel against the stops
14. Verify the following conditions  The steering is smooth  Noiseless operation  Proper fluid level  No leaks  Proper fluid condition  No bubbles, foaming or fluid discolouration
15. If all of the above conditions are satisfied the bleeding procedure is complete
16. If any problem exists then turn off the engine and see special conditions below Special Conditions If you experience any of the conditions listed below then there is still air in the system.  Foam or bubbles in the fluid  Power steering fluid should not rise in the reservoir when the engine is turned off, if this occurs there is air trapped in the system  Be aware of any periodic bubbles that could indicate a loose connection, leaky o-ring or a bad flare seat in either the pressure or return hose  Discoloured fluid (milky, opaque or light tan colour)
Thanks I'll definitely
Check into that thank you !
or try this
1 - 4 of 4 Posts
