1 - 1 of 1 Posts
pressure sensor installation said cut the vacuum line on the fuel regulator and install the 3 way fitting.
one goes to intake manifold and fuel pressure regulator,but where is the fuel pressure regulator? :dontknow:
on valve installation (com) port goes to actuator and (no) port goes to the pressure source, so would the pressure source mean intake manifold also?
the airinx is connected to assist control valve, is that the brake booster?
and do i need to plug the airinx hole to use the profec?
so where would the brake booster line goes to then?
1 - 1 of 1 Posts
