1 - 1 of 1 Posts
Not Plugged In
This is for a non-SI.
I installed Progress springs and the skunk2 rear camber kit. I had a squeaking noise in the rear, lubed up the bushings on the camber arms, and it seemed fine. The other noise I get is from the front. Its mostly on the driver side. Its as if metal is hitting metal. I doubled checked the center nut, and its tight. When I put my hand around the springs, I notice very little clearance. The noise only happens over speed bumps or raise manholes. On a smooth surface, I get no noises.
The narrow end of the spring is on top and the fatter end is on the bottom which is also how the spring mount is on the shock. I know the coils are wound tighter on the bottom, just like the RSX.. so everything looks installed right.
any ideas?
1 - 1 of 1 Posts
